  4. The shape of the T1 image and the shape of the electric field are different
18 Posts 2 Posters 5.9k Views 2 Watching
    lucky_lin
    I used the IXI025-Guys-0852-T1 image for head segmentation and then performed TI (tissue imaging) simulation. However, I found that the shape of the T1 image and the shape of the electric field are different. My simulation grid setting is 1 mm. Why is this the case?b7bbe15a-8844-4142-9372-06a204a6f2d4-image.png
      lucky_lin
      I tried to change the grid size but still couldn't make it exactly the same as the T1 image. I wonder if it's possible to control the electric field slices to be exactly the same as the T1 image.
        You don't have the same resolution (grid spacing) in the T1 image and the efield...!
        To visualize the two "fields" on the same grid, drag the T1w image to the analysis explorer, and interpolate it on the e-field grid.
        The interpolator has two inputs:
        1. T1w image (input field)
        2. E-field (target grid)
        Here is a snippet to show this could be done in Python
        # Add a new ModelToGridFilter
        inputs = []
        model_to_grid_filter = analysis.core.ModelToGridFilter(inputs=inputs)
        model_to_grid_filter.Name = "Image"
        model_to_grid_filter.Entity = model.AllEntities()["T1w-image"]  # The model entity corresponding to the T1w-image
        model_to_grid_filter.UpdateAttributes()
        # Add a new SimulationExtractor
        simulation = document.AllSimulations["EM"]
        # Add a new EmSensorExtractor
        # Add a new FieldInterpolationFilter
        inputs = [model_to_grid_filter.Outputs[""], em_sensor_extractor.Outputs["EM E(x,y,z,f0)"]]
        field_interpolation_filter = analysis.core.FieldInterpolationFilter(inputs=inputs)
        field_interpolation_filter.UpdateAttributes()
        document.AllAlgorithms.Add(field_interpolation_filter)
        Then you will have the same grid and array ordering, and can overlay the T1w image and the field (or display them side by side with identical aspect ratio).
        Note if your simulation grid is not uniform, matplotlib will depict the anatomy in a distorted way.
        Btw, you could also interpolate in the other direction ...
        L 1 Reply Last reply
        • brynB bryn
          inputs = []
          lucky_lin
          @bryn Can I export the new T1.nii.gz file? The T1 and the electric field seem to be in opposite directions along the x-axis. If I can export it, will the new T1 have the same orientation as the original one?
            what do you mean by "The T1 and the electric field seem to be in opposite directions along the x-axis"?
            • the interpolated T1 image and the E-field?
            • is the interpolated T1 image NOT shown in the same position/orientation as the original T1 image from the modeler?
            • is the original T1 image (which you imported in the modeler) aligned/shown in the same position/orientation as the model?
            It would help if you would add screenshots to your question, with explanations of what each screenshot is trying to demonstrate.
            • brynB bryn
              lucky_lin
              @bryn What I mean is that the slice with index 0 in the T1 image and the slice with index 1 in the electric field are not on the same side of the head model along the x-axis. Additionally, I would like to know if it is possible to export the interpolated T1 image. I need the T1 structural image that corresponds to the simulated electric field to create a dataset.
              c2b26fe5-7cd7-465e-9e27-81b29b410516-image.png 8c9a6f68-03be-4d1c-8a88-8ce3eab8c903-image.png
                but are you using a slice field viewer to show the interpolated MRI slice? If not you basically are looking at the original MRI, with different grid and data ordering.
                • brynB bryn
                  lucky_lin
                  @bryn I don't know how to use the slice viewer to inspect the T1 image. I just want to export it.
                    #9
                    I sent you code (it can also be done in GUI) above to interpolate the T1w image onto the E-field/simulation grid. If you do that you can export it in the same format as you export the E-field (not as a nii.gz file, since the simulation grid is rectilinear which is not supported by nifti files).
                      lucky_lin
                      wrote on last edited by lucky_lin
                      #10
                      @bryn Is the following code correct? I'm not sure if the input is correct.
                      inputs1 = [model_to_grid_filter.Outputs[""]]
                      field_data_text_exporter1 = analysis.exporters.FieldDataTextExporter(inputs=inputs1)
                      field_data_text_exporter1.FileName = output_file1
                      field_data_text_exporter1.UpdateAttributes()
                      document.AllAlgorithms.Add(field_data_text_exporter1)
                      field_data_text_exporter1.Update(overwrite=True)
                        this does not include the interpolation...
                        to access an output of an analysis algorithm you can use named outputs or indexed outputs, in your snippet above it may be easier to use the index '0'.
                        inputs1 = [model_to_grid_filter.Outputs[0]]
                        • brynB bryn
                          lucky_lin
                          @bryn Thank you!!! I'll give it a try!^^
                            lucky_lin
                            #13
                            @bryn After executing the code, an error occurred that prevented the export of the txt file.
                              looking at the error 'Unable to create destination file', I would guess you are trying to write to a directory that does not exist (yet) or without write permissions
                                lucky_lin
                                However, the electric field data can be exported.
                                  what does your code look like? I create the pipeline in the GUI and it seems to run fine for me (v9.0.0). The "To Python" function yields
                                  # This script was auto-generated by Sim4Life version 9.0.1
                                  import numpy
                                  import s4l_v1.units as units
                                  from s4l_v1 import Unit
                                  try:
                                      ReleaseVersion.set_active(ReleaseVersion.version9_0)
                                      # Adding a new ModelToGridFilter
                                      inputs = []
                                      model_to_grid_filter.Name = "IXI025-Guys-0852-T1"
                                      model_to_grid_filter.Entity = model.AllEntities()["IXI025-Guys-0852-T1"]
                                      document.AllAlgorithms.Add(model_to_grid_filter)
                                      # Adding a new FieldInterpolationFilter
                                      inputs = [model_to_grid_filter.Outputs[0], em_sensor_extractor.Outputs["EM E(x,y,z,f0)"]]
                                      # Adding a new FieldDataTextExporter
                                      inputs = [field_interpolation_filter.Outputs[""]]
                                      field_data_text_exporter = analysis.exporters.FieldDataTextExporter(inputs=inputs)
                                      field_data_text_exporter.FileName = u"D:\\temp\\ExportedFieldData-T1w.txt"
                                      field_data_text_exporter.UpdateAttributes()
                                      document.AllAlgorithms.Add(field_data_text_exporter)
                                  except Exception as exc:
                                      import traceback
                                      traceback.print_exc()
                                      # Reset active version to default
                                      ReleaseVersion.reset()
                                      raise(exc)
                                    lucky_lin
                                    #17
                                      your code is still not using the FieldInterpolationFilter to interpolate the T1w image onto the same grid as the E-field. Note, the FieldDataTextExporter takes the output of the interpolator as input
                                      • brynB bryn referenced this topic on
                                      • T tbone referenced this topic on
