  4. Understand the h5 file structure
3 Posts 2 Posters 1.6k Views 2 Watching
    Seif_Elkerdany
    After running the simulation the results are saved on my computer as h5 file so I want to understand how the sensor readings are stored in the h5 file.
    I want to extract the current density value per voxel. Is it feasible if I have the result h5 file?
      The current density is computed on the fly in the sensor extractor in Sim4Life. It is not stored in the .h5 file.
        to get the current density in Python you could use a script like
        try:
            # add a SimulationExtractor for the simulation call "LF"
            simulation = document.AllSimulations["LF"]
            # create an EmSensorExtractor
            # update the pipeline, make sure current density is extracted
            em_sensor_extractor.Outputs["J(x,y,z,f0)"].Update()
            # get data
            current_density_field = em_sensor_extractor.Outputs["J(x,y,z,f0)"].Data
        except Exception as exc:
            import traceback
            traceback.print_exc()
