  4. T-Neuro
  5. Importing NEURON .hoc files in Sim4Life
Scheduled Pinned Locked Moved T-Neuro
2 Posts 2 Posters 763 Views 2 Watching
    GeremiaLombardi
    I would like to import into Sim4Life a neural network model that was originally implemented in the NEURON simulator.
    The model includes several .hoc and .mod files.
    Is there a way to adapt or convert these files to make the model compatible with Sim4Life?
    Has anyone successfully imported NEURON network models (not just single neurons) into Sim4Life before?
      guillermo
      Dear Geremia,
      Here is the procedure I use for S4L:
      Prerequisites:
      The Yale Neuron compiler 8.2.6 for Windows
      https://github.com/neuronsimulator/nrn/releases/tag/8.2.6
      You can use newer versions, but this one works best with S4L.
      • Create a directory for a particular neuron structure, at root level: hoc files, asc, etc. a subdirectory called 'mechanisms': all your mod files.
      • From a console, run the Yale Compiler on your 'mechanisms' directory:
        > nrnivmodl
        if it succeeds, it will create a nrnmech.dll file.
      • move the nrnmech.dll file to root level (where your hoc files are) and clean the 'mechanisms' directory - all the .c and .o files.
      • Compress into a zip file the main directory (that contains the hoc files, nrnmech.dll and 'mechanisms' dir). Change the extension to .hocz
      • Now, in S4L use the import button to import your new neuron model, your newly created hocz file.
      Regards,
      Guillermo
