  3. Installation & Licensing
  4. How to set the windows as default?
5 Posts 3 Posters 3.6k Views 3 Watching
    Saya
    The windows (explorer, options, properties) in Sim$Life are messed up.
    There is an option "Docking" to fix windows, but using it the windows are placed next to each other. How it could be set as default?
    Thanks.
    • ofliO Offline
      Hi Saya,
      You can delete the UI settings of Sim4Life from the Registry:
      • type "regedit" in the Windows Run command line
      • navigate to HKEY_CURRENT_USER\SOFTWARE\Schmid & Partner Engineering AG\Sim4Life\4.4\SuperMash\Settings
      • delete the entire Settings folder
        This forces Sim4Life to rearrange the dockable windows in default configuration and automatically re-write this registry entry.
        Saya
          Saya
          Hi Ofli,
          It worked. Thanks.
          • T Offline
            T Offline
            TimHarrigan
            I can't find the explorer window anywhere. Any hints on finding it? I'm using version 6.2
