  4. Obtain material properties from material database
python apidatabasematerial
3 Posts 2 Posters 2.1k Views 2 Watching
    rediponi
    When using the GUI, drag and dropping a ViP model to the material settings automatically creates the tissue properties and assigns entities of the ViP model to each tissue property.
    I am trying to perform the same task through the python API.
    Assuming that I obtained all ViP model entity names, how can we assign automatically the tissue property from the database ?
    thanks
    redi
      Redi! Have you tried doing exactly that through the GUI and then right clicking the simulation and selecting 'To Python..' if I remember correctly that shows you how to assign materials to the database.
      Just tried it and I get something like this:
      import s4l_v1.materials.database as database
      # Adding a new MaterialSettings
      material_settings = acoustic.MaterialSettings()
      components = [entity__block1]
      mat = database["IT'IS 4.0"]["Brain (Grey Matter)"]
      if mat is not None:
      	simulation.LinkMaterialWithDatabase(material_settings, mat)
      else:
      	# Fallback if material is not found
      	material_settings.Name = "Brain (Grey Matter)"
      	material_settings.MassDensity = 1044.5, Unit("kg/m^3")
      	material_settings.AttenuationCoefficient = 1.2, Unit("Np/m")
      simulation.Add(material_settings, components)
      Never tried it with the ViP model but should work.
        rediponi
        Hi Haza,
        yes, i managed to get the corresponding material with :
        tissue_X_entity.MaterialName
        Each entity of the anatomical model has this attribute which is visible also through the GUI.
        thanks
