  4. Why using a sensor in the simulation changes the results?
3 Posts 2 Posters 1.4k Views 2 Watching
    I'm wondering why the results (for example E-field or SAR value) change after adding a point sensor or line sensor to the simulation?
      Sensors by themselves do not affect results. However, adding a sensor to a simulation may change the grid, which may change the voxels, which may change the results.
      If adding sensors brings "unacceptably large" changes, it is usually a good indicator that your grid was (and probably still is) too coarse.
        Thanks for your reply.
