  3. Installation & Licensing
  4. Troubles setting up new installation of Sim4Life
Scheduled Pinned Locked Moved Installation & Licensing
8 Posts 4 Posters 3.2k Views 4 Watching
  • PeterStijnmanP Offline
    PeterStijnman
    So today I switched to a windows 10 PC at work and wanted to install Sim4Life (tried V3.4 first). It works, however, there were some strange things occuring:
    • It starts up in the light theme and for some reason I cannot seem to find the option to switch it in the UI.
    • Further if i change something in the File ->Preferences tab it is unable to save the changes.
    • And finally when I open a project file (.smash) it creates (next to the regular backups) a "Material" and "Scripts" folder where the project is located. Which I can't recall it doing previously.
    So I tried to uninstall and try V3.4 again. Same thing happened. Afterwards, I tried V4.2 and again the same thing.
    Does anyone know a solution to the above problems?
    Thanks in advance!
      I have seen that happening before but I am not sure what was the reason. If I were you I would first try to update the graphics card driver, since this "light theme" sounds like some components of the GUI are not loading properly.
        PeterStijnman
        As far as I can tell everything is up to date.
        Attached is how the UI loads up right now.
          Andrei
          I installed and reinstalled Sim4Life trial and installed iSEG_v3.10.25.60 but Database does not mount materials to models. I manually installed the database in the Material folder, but the problems remained.
          The user name is written in ASCII format.
          Second problem: Dicom series is not imported into iSEG. When I try import Dicom file in iSEG the program closes.
          Can you help me?
           Best regards
             Andrei
          PeterStijnmanP 1 Reply Last reply
          • A Andrei
            Can you help me?
             Best regards
               Andrei
            PeterStijnman
            @andrei Hey sadly I cannot help you with this problem, you might want to make a new thread/post about this. Cheers Peter
            • F Offline
              F Offline
              Frodi
              Hi @PeterStijnman or anyone else,
              I this problem fixed for you now? I seem to have the same problem as you.
              Best,
              Frodi
                @Frodi, have you checked this post: https://forum.zmt.swiss/topic/97/problens-with-sim4life-demo ? There is a known issue concerning the material database when the operating system makes use of non-ASCII characters in the path to the database (it also happens when the user name contains non-ASCII characters).
                  PeterStijnman
                  Okay, a short update on this issue:
                  I did absolutely nothing and it is fixed for me some how...
                  There might have been a windows update that fixed the problem, not sure about that though.
                  Curious if others have seen similar result.
