  4. Compute the total current flowing between two electrodes in an Electro Quasistatic LF simulation
fluxevaluatorimpedance
18 Posts 10 Posters 12.9k Views 11 Watching
    wrote on last edited by admin
    Assume we have an LF simulation with two electrodes, at + and - 1V, respectively, as shown in the voxel view below. We want to compute the total current flowing between the two electrodes.
    We start by creating a plane that cut through the computational domain, with each electrode in either part of the plane:
    We then use the Flux Evaluator to compute the total current flowing through the plane:
    H C 2 Replies Last reply
    • J Offline
      J Offline
      JKM
      Is there a disadvantage to calculating the current by using the power loss in the simulation domain and avoiding extra geometry? (i.e. R = (V^2)/P and then I = V/R using the "Total Loss" in "All Regions" from the SAR statistics evaluator?)
        The "Total Loss" approach works too. Be aware that it assumes that all the power dissipated by the system occurs via the Joule effect in conductive materials. In other words, it only accounts for Ohmic currents and neglects the contribution of Displacement current (like the current that flows between the two plates separated by air in a capacitor).
        This means you can use this approach if you could have used the Ohmic Quasi-Static solver instead of the Quasi-Static one (since the former neglects displacement currents, while the latter does not).
        For currents flowing between electrodes placed on a human body, displacement currents are typically negligible.
          LJ
          • D Offline
            D Offline
            daolin_qu
            Can I consider the current in the body during electrode stimulation like this? First, the simulation result can get the current density. Its unit is A/m². Assuming that the current current density is 100A/m², I want to calculate the current at a certain point in the muscle Intensity, I choose 1mm², then the current density at this time becomes 0.1mA/mm², can I consider the current intensity at the current position as 0.1mA?
              Current intensity is defined for a given cross-section. Usually, it is used for wires, where the cross-section is obvious, and it relates to the "amount of current" passing through the wire. A bit like the amount of water passing under a bridge, for a river (referred to as volumetric flow rate, or "discharge").
              For an infinitesimal point, it doesn't make much sense to speak of current intensity (or of flow rate, for the river analogy). The relevant quantity, in that case, is the flux of current (or water...), expressed in A/m2 (or volume/s/m2).
              I hope this helps.
                gbgbha
                Hi @Sylvain, thanks for the tips. Is the total evaluated flux returned in RMS or absolute magnitude?
                • G gbgbha
                  @gbgbha the evaluator would typically return a complex number, which should be interpreted as a phasor (at the frequency at which the fields were computed). Take the absolute value of that number to get the peak total current, divide by sqrt(2) to get the RMS.
                  • S Sylvain
                    hiTina
                    @sylvain when we create the plane to compute the current ,I want to know how to set up the plane in the stimulation tab? setting in the boundary condition or else? hope your reply.
                    • H hiTina
                      @hitina typically, you would create the plane in the Model tab of Sim4Life, then use it in the Analysis tab. Use the "Model-Tree" window to drag and drop the plane (or any other CAD object, for that matter) into the Explorer tree of the Analysis tab.
                      This creates a grid (Surface mesh) out of the CAD object that can be used for further postprocessing. Note that its mesh resolution can be changed (you would typically do that later, so you can see how it affects the end results when you refresh the pipeline).
                      By selecting the "Surface mesh" and any other field quantity (e.g. J(x,y,z,f0)), you can then make use of the "Flux Evaluator" algorithm. Use the Ctrl key to select multiple items.
                      I hope this helps.
                      • S Sylvain referenced this topic on
                      • S Sylvain
                        I hope this helps.
                        hiTina
                        @sylvain Thanks for your reply. I try to create a plane and drag and drop the plane into the Explorer tree of the Analysis tab.I enable the J(x,y,z,f0) and click the Flux Evaluator button. The result shows errors as follow.微信图片_20211022221230.png
                        How can I use the created plane to compute the current?微信图片_20211022221225.png
                        Should I set the created plane as the target surface of the flux evaluator ? the error shows invalid target surface at input. looking forward to your reply.
                        • H hiTina
                          @hiTina it's not clear from your post whether you selected both the J field and the surface before clicking "Flux Evaluator".
                          What I mean is that you should see something like this in the Output View and then click "Flux Evaluator"
                          Once you've done that, the Workbench would show something like this:
                          • S Sylvain
                            hiTina
                            @sylvain okay, thank you very much .I will try again.
                            • O oeddaoui referenced this topic on
                            • Paria M.P Offline
                              Paria M.P Offline
                              Paria M.
                              @Sylvain
                              Hi, I followed the steps you described in this post to obtain the flux between two electodes in my simulation. The resulted Total Flux is (-1.22514 mA/m^2 m^2). I want to nolmalize the E-field in my simulation to have the current of 1 mA/m^2 m^2 between the electrodes. Could you please guide me on how to do that using the "Field Normalizer" at field data tools section?
                              As seen in the attached picture, when I refresh the Field Normalizer, I get error.
                                @Paria-M You can use the field along with the averaged flux density and then use the field normalizer, for the target value you have to input the current in units of A/m^2.
                                • Paria M.P Offline
                                  Paria M.P Offline
                                  Paria M.
                                  @halder Thank you for your response. I want the total current of 1 mA flowing between my two electrodes. In this case, I should put the target value as (1 mA/area of the plane I have drawn between two electrodes)?
                                  since my plane area is 182mm*220mm, then I should select the target value to be 0.024975 A/m2. Is this the correct approach?
                                  • C Cindy645 referenced this topic on
                                  • S Sylvain
                                    Cindy645
                                    @Sylvain Hi Sylvain! Thanks for sharing the method. I tried it in this very simple structure but get unexpected result for current density. Also available at my post here https://forum.zmt.swiss/post/2071.
                                    I use the following very simple structure to test whether I am using the LF Ohmic Quasi-Static Solver correctly. The voltage comes out as expected but the current (density) is incorrect. I have these three electrodes of the same radius (1mm) stacking together (touching each other) in an electrode-cylinder-electrode configuration. I want to apply to a 2V (+1V top, -1V bottom) to the two silver electrodes and achieve a 1 kA current through. So I chose the cylinder material (copper) and length such that the resistance is 2 mOhm.
                                    After running the simulation, where I place a line as voltage sensor (it runs from 2mm offset from the top electrode to 2mm offset from the bottom electrode, in the centre), it gives a value of -1.9786V as expected.
                                    When I combine the J(x,y,z,f0) from the overall field and a plane I created and use flux evaluator to measure total current density as described here, unexpected resutls occur. I tried two different planes and they gave different results::
                                    1. A block with 0mm thickness and 1m x 1m in area in the middle of the cylinder parallel to the electrodes, result: 1 A/m^2, multiply by the area gives 1A
                                    2. A cylinder with 0mm thickness and 1mm in radius in the middle of the cylinder parallel to the elctrodes, resutls: 49.7369 A/m^2, multiply by the area gives 0.156mA
                                      (P.S. why the current density has a unit of [A/m^2 m^2]?)
                                    Model, Simulation and Analysis details are summaried in the screenshots attached. IMG_5162.jpg IMG_5163.jpg IMG_5164.jpg Screenshot 2025-01-12 at 21.26.50.jpg Screenshot 2025-01-12 at 21.27.16.jpg Screenshot 2025-01-12 at 21.27.32.jpg Screenshot 2025-01-12 at 21.31.17.jpg Screenshot 2025-01-12 at 21.34.49.jpg Screenshot 2025-01-12 at 21.35.28.jpg
                                      lorenero_99
                                      Hi, sorry to bother you. Do you happen to know how to calculate the current absorbed by the electrodes and the impedance?
