  4. Creating Cross Section of Anatomy
6 Posts 2 Posters 2.8k Views 2 Watching
    BrandomFB
    What's the easiest way of creating a 2D Cross Section of the Yoon-sun anatomical model? I'm just interested in seeing if some anatomical dimensions change when I use poser to get different postures.
    Regards,
    Brandom F.
      You can use the planar cut tool and create slices (for 2d) or cuts. You can multiselect all tissues you are interested in, but it might take a while for yoon-sun v4 depending on the number of tissues.
      B 1 Reply Last reply
        Planar Slice creates contours, which you can cover eg to compute area
        • brynB bryn
          BrandomFB
          @bryn Thanks! All this is made after creating the voxels right?
            @BrandomFB
            no, actually the Planar Cut tool is in the modeler:
            1. Pose the model, and Clone As Static.
            2. Select the tissues you are interested in.
            3. Modify -> Planar Cut -> Planar Slice (button in the 3D view)
            4. Wire Tools -> Cover Loops (to create surface from closed contours)
            5. Tools -> Geometry (to measure area)
            2
            • brynB bryn
              @BrandomFB
              BrandomFB
              @bryn Thank you very much! Really appreciate it! I was doing the slicing from the voxels. Definitely, this approach is way better.
              Regards,
              Brandom F.
