Python API
144 Topics 449 Posts
Scripting interface for Sim4Life
  • draw hemisphere
    thank you! It works I finally had to separate the two hemispheres because I wanted to impose a boundary condition on one sphere and a different boundary condition on the other, but if they were too close it didn't work. [image: 1619186169986-69ed604f-852c-43d3-b4df-4b4c43b5a472-image.png]
  • "Scripter" troubles
    When starting and initializing Sim4Life, I do also get the error mentioned before in another thread "Error: too many positional options have been specified on the command line"
  • Plot Ellipsoid
    Thanks for the answer, it works! I hadn't seen the feature Stretch.
  • how to use python API
  • how to Create PolyLine using an array of points with 100 elements
    E
    yes you can. Use the function CreatePolyLine from the module XCoreModeling This function takes a list of points as input. Points need to be Vec3 objects smth like: import XCoreModeling from s4l_v1.model import Vec3 #points is your array of 100 points with spatial coordinates points = [Vec3(p) for p in points] XCoreModeling.CreatePolyline(points)
  • Python code does not work with S4L v.6.0
    PeterStijnmanP
    It might be that they changed the sim4life python module between the two versions. You could check the functions you call from the sim4life module in the API browser. If that doesn't work, I would suggest posting the code (or a minimal working example) here so people can look more specifically.
  • Forcing imported modules to refresh after updating
    import file python
    This is common. Once you import a script, it becomes cached so even if you make changes to it and save it, python won't see the changes. You need to reload it as you said if you make changes to the imported script after running your main script.
  • Applying smoothing to a mesh with the API
    This looks quite good, thank you for providing your scripts. Note that, for the second method, you could create your cylinder directly at the desired position: cylinder2 = model.CreateSolidCylinder(Vec3(0,1,-15),Vec3(0,1,-15),0.5) There is also the XCoredModeling.CoverWires() function that allows you to make a surface (i.e. face) out of a circle entity. Last, but not least, note that the line model_to_grid_filter.MaximumEdgeLength is ultimately what determines the tradeoff between accuracy and computational cost of the interpolation (since it defines the resolution of the triangulated mesh on which the interpolation is done).
  • Simulation results show as nan+nanj
    Oh that worked! Thank you
  • plot a specific parameter on a surface
    Thank you for your prompt reply! That's helped a lot, I didn't know how to implement the 'magnetic_energy_evaluator.Outputs["Magnetic Energy"].Data' or the 'mag_data.GetComponent(0)[0]' lines. I realise now that I probably should have posted the code which I had attempted already. Thanks for helping me anyway!
  • Acoustic simulation - phase information needed (using Python)
    11
    You need to make output_angle into an array and append the new values at the end every time (the i-th element will have the i-th phase you want) output_angle = numpy.array([]) for i in range(0,128): # your code output_angle = numpy.append(output_angle, numpy.angle(output))
  • Add a material to the Materials Database
  • use vtk on entities in s4l enviroment
  • Extract voxel information
    W
    I figured it out, made it in the gui and used to python to see what the syntax had to be inputs = [field_masking_filter.Outputs["EM E(x,y,z,f0)"]]
  • Accessing the results of the simulation via python scripting
    Not sure what you're trying to do, but some sample code to extract the field and data is below (should apply to anything with a rectilinear grid, but it's from Acoustic simulations): sim = document.AllSimulations[simulation_idx] simulation_extractor = sim.Results() sim_sensor_extractor = simulation_extractor["Overall Field"] # Sensor Name sim_field_extractor = sim_sensor_extractor.Outputs["Intensity"] # Field Name sim_field_extractor.Update() d_sim = sim_field_extractor.Data sim_ref_field_extractor.Update() out = d_sim_ref.Field(0) # 3D Field is extracted as a 1D array. # 0 corresponds to the snapshot (typically, time or frequency) # If you need this as a 3D array then use # out_3d = np.reshape(out, grid_dims, order='F') # once you have 'grid_dims' which I show how to get below # important to remember order = 'F' because of the way that 3D arrays are unrolled into 1D (Fortran style) sim_field_extractor.Update() # Just to be safe, I add this update step a few more times than needed # Get grid: axes, dimensions x = d_sim.Grid.XAxis y = d_sim.Grid.YAxis z = d_sim.Grid.ZAxis # Careful: Simulations in S4L have grids defined at the nodes, and values (the field) defined at cell centers # Therefore if you want the 'grid' used for the values in your field, you'll need to probably get the midpoints of the grid and reduce the grid dimensions by one in each direction. # Something like: x_mid = (x[1:]+x[:-1]) / 2 grid = d_sim_ref.Grid.Dimensions
