Python API
144 Topics 449 Posts
Scripting interface for Sim4Life
  • Extract the bounding box of a solid
    Pinned
    There is a function that returns the bounding box of an entity. Let us assume you have an entity called 'object 1'. The following code should return the coordinate vectors of two diagonally opposite corners of the bounding box: import s4l_v1.model as model import XCoreModeling entity = model.AllEntities()['object 1'] bb_lower, bb_upper = XCoreModeling.GetBoundingBox([entity]) You can then use the model.CreateWireBlock() function to create an object which you can use in your simulation settings. For more detail: help(XCoreModeling.GetBoundingBox) help(model.CreateWireBlock)
  • Moving from SEMCAD 14.8 to Sim4Life python API
    Pinned python semcad
    2 Votes
    pcrespoP
    @pcrespo said in Moving from SEMCAD 14.8 to Sim4Life python API: How can we synchronize the entities in a model with a simulation (say, s4l_v1.simulation.emfdtd.Simulation)? Previously, the SolidRegions in a simulation seemed to be synchronized with model entities automatically, but it seems that SolidRegions are not available in simulations anymore. Yes, the philosophy there changed a bit. The idea is that every context adds a new layer of information on top of the previous one. When the user starts modeling, it is expected to define the geometry of the problem. For instance, what is the shape, position and size of a given entity. The simulation context adds the necessary information to the geometry of the problem so that we can perform a numerical simulation. These new settings could be related with the physics of the problem (e.g. electric properties of a given geometry ) or with the numerical method (e.g. fdtd grid details for the discretization of a given geometry). Creating a simulation in the UI reveals what type of settings each simulation type adds on the associated modeling entities. Another big different with respect to SEMCAD is that every simulation uses a selection of entities instead of using by default all and having to unselect/ignore them. It has the same result but the producer is reversed. Then, coming back to the API, assume we want to simulate a dipole antenna.. To start I modeled two arms and a line to define the feed. I can retrieve them by name as follows: import s4l_v1.model as model entities = model.AllEntities() arm1 = entities['Arm 1'] arm2 = entities['Arm 2'] line = entities['SourceLine'] Now i want to create a simulation that uses this geometry. In order to assign a material to these entities, I need to a) associate the entities to the simulation (they become simulation components) b) create material settings and c) assign these settings to the associated entities. The API provides a shortcut for these three operations simulation.Add*Settings . This directly returns the settings object assigned to the entity within this simulation. Then we can set the values of the different properties: simulation = fdtd.Simulation() # ... some general settings ... # Materials: dipole_material = simulation.AddMaterialSettings([arm1, arm2]) dipole_material.Name = 'Dipole Arms' dipole_material.MaterialType = dipole_material.MaterialType.enum.PEC and analogously with the line entity: edgesrc_settings = sim.AddEdgeSourceSettings([line,]) options = edgesrc_settings.ExcitationType.enum edgesrc_settings.ExcitationType = options.Gaussian edgesrc_settings.CenterFrequency = 300., units.MHz edgesrc_settings.Bandwidth = 300., units.MHz The model entity in a simulation and with all the extra layers is now referred as a simulation component. In other words, a simulation component is a geometry (defined by model entity) with several layers of settings corresponding to the physics and the numerical methods.
  • API Documentation - searching for functions
    Pinned python documentation api browser
    "Experimental" in that context means that the API may change in the future and that backward compatibility may break.
  • A list of useful Sim4Life Python API snippets in a real project
    3 Votes
    thanks Robin!
  • MATCH module support missing workarounds?
  • VSCode extension not stopping on breakpoints during debugging
    Hi parsley, This is a known issue that is currently in our backlog. A fix will be included in a future release. Thank you for your feedback and your interest in the Sim4Life VSCode extension.
  • Importing electrode positions recorded in RAS coordinates
    T
    @bryn Thank you for your detailed response! I had overlooked that Sim4Life loads images in LPS orientation, but using your function I was able to correctly place the electrodes at the intended coordinates. I was wondering as well, if I wanted to compute the resulting E-fields per ROI based on the Brainnetome Atlas (BNA), what would be the recommended way? Would it be better to: Interpolate the E-fields onto the T1w image like you have mentioned here https://forum.zmt.swiss/topic/735/the-shape-of-the-t1-image-and-the-shape-of-the-electric-field-are-different/18, then warp the BNA atlas into the subject's T1w space? Or Export the E-field as '.vtk', and then use the information directly to group field values according to atlas labels (labels are warped BNA-> subject): mesh = pv.read(r"MaxModulation_Efield.vtk") mesh_p = mesh.cell_data_to_point_data() # only cell data exists points = mesh_p.points * 1000 # mesh (m) to (mm) points_ras = points.copy() # LPS to RAS points_ras[:, 0] = -points[:, 0] # Left <-> Right points_ras[:, 1] = -points[:, 1] # Post <-> Ant # Mesh (world coords) to atlas voxel indices points_h = np.c_[points_ras, np.ones(len(points_ras))] voxels = (inv_affine @ points_h.T).T.astype(int) I would really appreciate your feedback on how to accurately compute this. Thank you again for your help!
  • Export CT voxel data aligned with SAR/EM grid for use in Python
    Btw, this topic is quite similar https://forum.zmt.swiss/topic/735/the-shape-of-the-t1-image-and-the-shape-of-the-electric-field-are-different
  • Current density to CSV
  • Inquiry Regarding TI Simulation Setup in Sim4Life
    Hi, I strongly recommend you have a look at the tutorial 3.2.12 called Temporal Interference with Complex Head Model. It should be of significant help for setting up a TI simulation correctly. As for your specific questions: yes, that's correct. You can actually get the full Python script that generates a given simulation from the GUI by right-clicking on the simulation in the Explorer tree and selecting "To Python". Very useful That will most likely not work. Instead, you should apply fixed voltage Dirichlet conditions (e.g. +/- 1V) and re-normalize your results at post-processing (see screenshot below) For most fields that you can see in the analysis, you can use the Imp/Export menu in the ribbon and find a format in which to export (e.g. Matlab, VTK, or even plain text). [image: 1756718002390-0c790cba-feab-4bf1-a1c2-c6c1b959649c-image.png] [image: 1756718129268-fdbe02f0-7b3a-4d2e-a68d-989752dd05a7-image.png]
  • Export to CSV file
    K
    The problem has been resolved! Thank you for your assistance!
  • Error in TI tutorial
    19
    11k Views
    BTW. this is a temporary fix, which breaks inline plotting with matplotlib. We have fixed it in the release branch. A slightly improved workaround may be to temporarily unset the MPLBACKEND environment variable before the call to HeadModelGeneration, e.g. something like this import os original_backend = os.environ.pop("MPLBACKEND", None) labelfield = HeadModelGeneration( images=image_list, add_dura=True, close_skin=True, close_csf=True, close_skull=True, version=ImageML.eHeadModel.head16, ) if original_backend is not None: os.environ["MPLBACKEND"] = original_backend
    thanks for this feedback. we will try to add more examples that demonstrate how to use/modify anatomical models, triangle meshes, etc.
  • Extraction of Tissue Properties Along a Spline
  • Importing STL as Solid body
    I tried to reproduce this doing the following. I create three entities a cylinder copy it and convert the copy to a triangle mesh generate an unstructured tetrahedral mesh Then I drag these entities to the Analysis (ModelToGridFilter in Python API). I tried to use the surface viewer, but since they have no fields, nothing is displayed (this changed since 7.0 or before - it used to display a white surface). To generate a field I used the Calculator, and added expressions like coordsY*jHat, i.e. (0, coordsY, 0) where coordsY is the y-coordinate from the points in the geometry. Create a vector viewer for each (from the left: Solid Body, TriangleMesh, UnstructuredMesh). The third one samples vector values using Line/Plane/Box sources. [image: 1749109986009-d5bc2f0e-af54-4fca-8265-1431e94207ca-image.png] To get the vectors on the surface of the UnstructuredMesh, I had to first extract the surface, via Field Data Tools -> Surface Filter [image: 1749110185730-938040d9-2fcf-4cad-a42e-7c2f0d4592ec-image.png] The generated Python ("To Python' in context menu) script for item 5 was: # This script was auto-generated by Sim4Life version 8.2.0.16890 import numpy import s4l_v1.analysis as analysis import s4l_v1.document as document import s4l_v1.model as model import s4l_v1.units as units from s4l_v1 import ReleaseVersion from s4l_v1 import Unit try: # Define the version to use for default values ReleaseVersion.set_active(ReleaseVersion.version8_2) # Creating the analysis pipeline # Adding a new ModelToGridFilter inputs = [] model_to_grid_filter = analysis.core.ModelToGridFilter(inputs=inputs) model_to_grid_filter.Name = "Cylinder 3" model_to_grid_filter.Entity = model.AllEntities()["Cylinder 3"] model_to_grid_filter.UpdateAttributes() document.AllAlgorithms.Add(model_to_grid_filter) # Adding a new FieldCalculator inputs = [model_to_grid_filter.Outputs["Unstructured Grid"]] field_calculator = analysis.field.FieldCalculator(inputs=inputs) field_calculator.Expression = u"coordsZ*kHat" field_calculator.UpdateAttributes() document.AllAlgorithms.Add(field_calculator) # Adding a new FieldSurfaceFilter inputs = [field_calculator.Outputs["Result(x,y,z)"]] field_surface_filter = analysis.field.FieldSurfaceFilter(inputs=inputs) field_surface_filter.UpdateAttributes() document.AllAlgorithms.Add(field_surface_filter) # Adding a new VectorFieldViewer inputs = [field_surface_filter.Outputs["Result(x,y,z)"]] vector_field_viewer = analysis.viewers.VectorFieldViewer(inputs=inputs) vector_field_viewer.Data.Phase = u"0°" vector_field_viewer.Vector.Plane.PlaneCenter = numpy.array([0.05300000309944153, -0.03099999949336052, 0.012000000104308128]) vector_field_viewer.UpdateAttributes() document.AllAlgorithms.Add(vector_field_viewer) except Exception as exc: import traceback traceback.print_exc() # Reset active version to default ReleaseVersion.reset() raise(exc)
  • Python scripting padding settings
    T
    This is in an older version of sim4life 8.0, maybe the problem has already been fixed. Otherwise I think this was a multiport simulation but I forget now... Maybe that could be a strange bug where it works for multi but not single or vise versa.
    So my problem was solved for the simple phantom a sphere. It can be voxeled. I am having a discussion with chatgpt about how to load Duke into the simulation section because currently it wont be voxeled. Is there a simple few lines of code that loads Duke and all the default tissue electrical properties or is it necessary to assign each tissue type in a loop or via thousands lines of code (as I have seen elsewhere)....
    @Sylvain I exported the electric field results from an AC simulation and found that the last six columns of the data are imaginary numbers. Are these the electric field values in three different directions? Why aren't they time-varying? Did I only export the peak values?
  • AttributeError: 'NoneType' object has no attribute 'Results'
    Hi, You would get that error if there was no simulation named "0_17_35_29" in the currently opened document. Maybe you should check what simulations you have in your project and if you do have a simulation with that name? One way to list all simulation names via python is to run something like: for s in document.AllSimulations: print(s.Name)
