Python API
144 Topics 449 Posts
Scripting interface for Sim4Life
  • Algorithm "Max Modulation" was not yet exposed in the Python API
    19
    11k Views
    @halder When I performed TI simulation using the spherical model, I found that if I changed the current direction of one pair of electrodes, the maximum value of the TI Max (x, y, z) slice remained unchanged. Changing the current of one pair of electrodes should have shifted from the original same-direction superposition to a reverse weakening, so why does it remain unchanged? Is it because Max Modulation only uses EM for calculations?
  • Access data directly
    Hi, you can try something like the following to extract the reflection coefficient. You can always try to build extraction manually once and select "To python" by right-clicking on the end of the tree (i.e. the component you extract from your pipeline) import numpy import s4l_v1.analysis as analysis import s4l_v1.document as document import s4l_v1.model as model import s4l_v1.units as units from s4l_v1 import ReleaseVersion from s4l_v1 import Unit sim_name = "MRI Volume Coil Cleg = 29.5 pF" ###### define the sim name in this case this is a multiport FDTD simulation Adding a new EmMultiPortSimulationExtractor simulation = document.AllSimulations[sim_name] em_multi_port_simulation_extractor = simulation.Results() this is extracting a port inputs = [em_multi_port_simulation_extractor.Outputs["MRI Volume Coil Cleg = 29.5 pF - Endring source 1 (Birdcage 1)"]] em_port_simulation_extractor = analysis.extractors.EmPortSimulationExtractor(inputs=inputs) em_port_simulation_extractor.Name = "MRI Volume Coil Cleg = 29.5 pF - Endring source 1 (Birdcage 1)" em_port_simulation_extractor.UpdateAttributes() document.AllAlgorithms.Add(em_port_simulation_extractor) em_sensor_extractor = em_port_simulation_extractor["Endring source 1 (Birdcage 1)"] document.AllAlgorithms.Add(em_sensor_extractor) ref_coef_data = em_sensor_extractor.Outputs["Reflection Coefficient(f)"] ref_coef_data.Update() freqlist = ref_coef_data.Data.Axis ref_coef = refCoeff.Data.GetComponent(0) ref_coef_magnitude = np.sqrt(np.real(ref_coef)**2 + np.imag(ref_coef)**2) import matplotlib.pyplot as plt plt.plot(freqlist,ref_coef_magnitude)
  • How to suppress messages in the Python console?
    As far as I'm aware it is not possible to suppress those messages. Maybe try writing your customized messages into a log file instead?
  • How to create voxels using a script?
    Hi! In all the tutorial python scripts this is shown. Within the python scripter you can click on the folder icon and choose "Open Example Script". There you will find lots of python scripts, that show how this is done. Here a small excerpt from the script "tutorial_emlf_parallel_plate.py": sim = CreateSimulation() s4l_v1.document.AllSimulations.Add(sim) sim.UpdateGrid() sim.CreateVoxels(path) sim.RunSimulation(wait=True) I suggest always creating a simulation, and an analysis function, that is then called in the RunTutorial function. It's best to then also create a main: def RunTutorial( path ): import s4l_v1.document s4l_v1.document.New() CreateModel() sim = CreateSimulation() s4l_v1.document.AllSimulations.Add(sim) sim.UpdateGrid() sim.CreateVoxels(path) sim.RunSimulation(wait=True) AnalyzeSimulation(sim) def main(data_path=None, project_dir=None): """ data_path = path to a folder that contains data for this simulation (e.g. model files) project_dir = path to a folder where this project and its results will be saved """ import sys import os print("Python ", sys.version) print("Running in ", os.getcwd(), "@", os.environ['COMPUTERNAME']) if project_dir is None: project_dir = os.path.expanduser(os.path.join('~', 'Documents', 's4l_python_tutorials') ) if not os.path.exists(project_dir): os.makedirs(project_dir) fname = os.path.splitext(os.path.basename(_CFILE))[0] + '.smash' project_path = os.path.join(project_dir, fname) RunTutorial( project_path ) if __name__ == '__main__': main()
  • import element inside a group using python
    Thank you, I could obtain the same also using this: analysis.exporters.MatlabExporter.ExportTo(matlab_exporter,matlab_exporter.FileName) Do you think it is a good solution as well?
  • python script to run in the cloud
  • Is it possible to use Python API without opening Sim4Life?
    You can open a smash file using import s4l_v1 as s4l s4l.document.Open(smash_file_path) You can save it using s4l.document.Save(smash_file_path) You can find a simulation using (assuming you have unique simulation names sim = [sim for sim in s4l.document.AllSimulations if sim.Name == "the name of your simulation"][0] If you want to load different models (from .sab file or .smash), but don't need to load e.g. simulations (in .smash file), you can import the file entities = s4l.model.Import(file_path) if you need to reset the document or model because you are accumulating too many entities and memory use is getting too high, you can use e.g. # reset the model sl4.model.Clear() # or keep entities, but discard model history import XCoreModeling as xcm xcm.GetActiveModel().ClearHistory() # or reset entire document (reset model, simulations, analysis) s4l.document.New()
  • Location of Simulation Outputs and Voxel Coordinates?
  • About TI Simulation
    I want to see the impact of different grid sizes on the simulation, so I cloned a pair of simulations and modified the maximum step size of the grid. However, I found that if I create a new pair of simulations using the same settings, the grid sizes, simulation durations, and results of the new simulations and the cloned simulations are all different. Why does this happen?
  • Iso Surfaces - Creating volumes with a threshold
  • Accessing specific entities of my model from the python API
    found my own answer: [image: 1730811141668-a0bbc3ce-5488-4bea-8af6-95ae9439824b-image.png]
  • Installing Additional Python Packages in Sim4Life Environment
    Solved python pip
    9
    @Sylvain Yes thanks finally I succeed!
  • Clear or Reset Geometry Workspace in Python?
    python geometry
    I typically do the following (which also clears the history and frees memory): import XCoreModeling as xcm xcm.GetActiveModel().Clear()
  • RuntimeError: Could not allocate memory for numpy array
    python numpy allocation
    have you tried overwriting the E_field and raw_data variables?
  • Extract the EM E field along the Spline
    Thank you so much for hour help with the technical issue! Your assistance made a big difference, and I truly appreciate your expertise and prompt support!
  • Max modulation tool in API
    Would like to know too in 2024
  • Change parameters in Simulation Combiner
    The following example for a 2-port simulation combiner should help. i = 0 for channel in em_multi_port_simulation_combiner.GetChannelWeights(): power = [1.0, 2.0] phase = [45, 90] em_multi_port_simulation_combiner.SetChannelWeight(channel, power[i], phase[i]) i += 1 em_multi_port_simulation_combiner.UpdateAttributes() em_multi_port_simulation_combiner.Update() document.AllAlgorithms.Add(em_multi_port_simulation_combiner)
  • Geometry Modeling - Snapping to Endpoints in Python API ?
    Solved python
    Hi @dbsim4 I think it would help a lot if you could post an image depicting what you are trying to achieve. Answering the question from the subject line: No, there is no snapping in Python (not sure how that API could look like), but there are functions to get the distance between entities (and corresponding closest points), which may help. brick1 = XCoreModeling.CreateSolidBlock(Vec3(0), Vec3(1)) brick2 = XCoreModeling.CreateSolidBlock(Vec3(2), Vec3(3)) res = XCoreModeling.GetEntityEntityDistance(brick1, brick2) print(f"Distance brick1-brick2: {res[0].Distance}") print(f"Closest point on brick1: {res[0].ClosestPosition}") print(f"Closest point on brick2: {res[1].ClosestPosition}") or distance to a point: brick = XCoreModeling.CreateSolidBlock(Vec3(0), Vec3(1)) res = XCoreModeling.GetEntityEntityDistance(brick, Vec3(3)) print(f"Distance brick-point: {res.Distance}") print(f"Closest point on brick: {res.ClosestPosition}") For geometry that has end-points or corners, you could extract the vertices and again use distance wrt some other point as a way to write a script. edge = XCoreModeling.CreateEdge(Vec3(0), Vec3(1)) vertices = XCoreModeling.GetVertices(edge) assert len(vertices) == 2 for v in vertices: print(v.Position) brick = XCoreModeling.CreateSolidBlock(Vec3(0), Vec3(1)) vertices = XCoreModeling.GetVertices(edge) assert len(vertices) == 8
  • How to create solid circle ie. with surface ?
    Solved
    @dbsim4 regarding your "Update", I am not sure I understand the context. Are you trying to assign the circle loop as an edge source?
