Python API
144 Topics 449 Posts
Scripting interface for Sim4Life
  • Creating a Custom Menu with Actions
  • Memory Problem with Python Scripts
    @CEiber That's a very good idea, thanks a lot!
  • Creating a 2D plot via Python API
    Hi, you get an error because your input is a 3D field (EM E(x,y,z,f0)) and this viewer expects 1D data (e.g. E as a function of x). To address this, you can use the 1D Field Filter (under Field Tools in the GUI) to first extract one-dimensional data out of your 3D field, and then connect the Plot viewer. Do it first in the GUI, then use To-Python function in the context menu to create your script. I hope this helps.
  • Extracting neuron simulation results
    To update, I've learned the membrane voltage, membrane current, and extracellular voltage can be specified as the measured quantity for a line sensor, with the number of time snapshots of your choosing. Thus, all info to calculate the induced potential on the electrode over time from neural activity is available, one just has to create multiple, identical spline entities as only one quantity can be sensed from a structure at at time (at least in the version of 5.0 that I'm using). This also helps get a relative idea of where the action potential initiates along the axon relative to the electrode, though not an exact X/Y/Z location to show in the model view.
  • How can I choose "Distribute Along Line = True"?
    Yes, this has solved the issue. Thanks a lot Silvain!
  • Missing psSAR in SAR statistics table when using Python API
    python sar api
    3 Votes
  • How to Create Disks in Implant Safety Tool with Python
  • Continuing Simulation and choosing Input Simulation
    For those who are interested, I have found a way to work around the issue. The python-command to continue a Simulation called: thermal_initial_global.InitializationOptions.enum.ContinueSimulation can only take the first argument, which in my case is "heating 0". So if you now have created "heating 1" based on "heating 0", and then proceed to delete "heating 0", the only available argument is "heating 1". This will enable you to further continue your simulation. You can delete a simulation using the following command: document.AllSimulations.Remove(thermal_sim) given you have returned thermal_sim, of course. If you create an empty list, you can append your thermal_sim's into it and then choose which item you want to delete. I am sure there are more elegant methods, but if you need to do this specific task, it works.
  • how to normalize in Simulation Combiner ?
    This might be an old question, but I have just stumbled accross this problem and solution recently. Someone reading this in the future might find it helpful. The code you were looking for is the following: #Sources heat_source = thermal_sim.AddHeatSourceSettings(em_sim.OverallFieldSensor) heat_source.NormalizeToInputPower = True heat_source.PowerScaleFactor = 6, units.Watts Assuming you want 6W of power, of course.
    N
    The problem has to do with (to me) unlogical ordering of the 'weights'-dict. I have made a workaround which extracts the values from the dict in alphabetical order of the keys, which seems to work.
  • Creating a simulation batch file for multiport simulation
    This should work: [outputname.replace('Output', 'Input') for outputname in [sim.GetOutputFileName(i) for i in range(sim.NumberOfResults)]] however, I could not find a way to programmatically generate the input files themselves, in case they are missing. First of all, the WriteInputFile() function is only available via sim.raw.WriteInputFile() (instead of simply sim.WriteInputFile()) and it only generates the input file for the first port (which is probably a bug in the API). One possible workaround (albeit not entirely satisfactory) is to call sim.RunSimulation(wait_for_submission=True) for all the multiport simulations, which will ensure that all input files are generated and all simulations are enqueued in ARES. You can then manually kill all of these submitted jobs from the Task manager of Sim4Life....
  • Xtracting S11 data via python
    Note: I would even recommend to raise an exception if the pipeline fails to update, before continuing with the data processing. This makes the scripts easier to maintain in the long run: S11 = simEM_results["EdgeSource (Dipole)"]["Reflection Coefficient(f)"] assert S11.Update(), 'Failed to update pipeline' S11_data = S11.Data.GetComponent(0)
  • Extracting a set of Voltage Value without Voltage Reader
  • Exporting data to excel (csv) or matlab (mat)
    AntoninoMCA
    Dear Redi, you can export arbitrary data to Matlab (e.g. field array and grid coordinates) using the Scipy.io library. A generic use of it is the following: import scipy.io as sio dict={'field':fieldarray,'xgrid':xgrid,'ygrid':ygrid,'zgrid':zgrid} sio.savemat(filename,dict) where xgrid,ygrid,zgrid are the vectors containing the cartesian coordinates of the grid.
    Brilliant, thanks!
  • Creating a wire from a line/arc
    Solved
    PeterStijnmanP
    Okay good to know!
