Installation & Licensing
37 Topics 128 Posts
Installing Sim4Life and configuring licenses
    Hi, yes, we have new agent in China and the contact email is zmt_china@163.com.
  • Sim4Life V 9.0.0.18820 License file does not support this version
    D
    Thank you so much!
  • Missing Material Database
    I believe the Materials.db) is copied from C:\Program Files\Sim4LIfe XYZ\data\... when you first run Sim4Life.exe
  • License Setup for iSolve on Linux
    Did you do one of the following: • Define the FlexNet environment variable FLEXID_LIBRARY_PATH to point to the location of the dongle shared object, libhasp_linux_x86_64.so. • Define the system environment variable LD_LIBRARY_PATH to point to the location of the dongle shared object libhasp_linux_x86_64.so. ? Could you try to send us the output of lmhostid -flexid? that command should return the dongle id. You can also access the dongle firmware - if it is correctly installed - via the loopback address. On a browser, go to http://localhost:1947/ you should see the characteristics of the dongle. Let us know if it works.
  • Start the Linux licensing daemon failed
    This looks like the drivers for the dongle are missing or have not been installed. Did you check the manual on how to install drivers for Linux? Also, it would help if you send us the full log. You can do that by emailing us at: s4l-support-group@zmt.swiss Regards, Guillermo
  • Sim4Life update v8.2
    Hi gc00, Apologies for late response. Do you still have the issue you reported above?
  • License Borrowing
    Hi Jack, no, it is not possible to "borrow" a license
  • Sim4life Installation
    Hi Abdou, this could happen if there are some libraries missing. Reinstalling the SW with the default options will help.
  • error in tutorial simulations
    Hi @Paul_fgp Could you please share any error messages you have received? Thanks
  • Error information in the console.
    These error messages can be safely ignored, but I will pass them along to see if such overzealous and misleading error messages can be suppressed in the future.
  • Error message related to "counters"
    You must be referring to this: This is windows configuartion related issue. You might not have access to log counter data, try logging in as an administrator. Later you can add user to the Performance Logs User Group. Look at this page for more details: https://learn.microsoft.com/en-us/windows/win32/perfctrs/limited-user-access-support
  • Error message when starting Sim4Life
  • Implementing on HPC cluster
    hpc linux
    That's great to hear! Thank you so much for sharing your experience. I'll explore the option of implementing something similar for EM simulation.
  • Activation code not accepted
    The problem has been resolved, thank you.
  • Sim4life on Ubuntu
    Hi, Please contact Sim4Life team via s4l-support@zmt.swiss. Thanks.
  • 7.2 Installation Problem on Windows10
    Thank you so much Erdem. This worked!
    Hi, I assume that you have received the dongle and the license file. You will find Sim4Life installer under the "Sim4Life" folder on the DVD you have received. Please run and follow the steps there. Once you are done with the installation, you need to install the dongle and license file. To do that, please run the "Install License" (via Start menu under Sim4Life V7.0 | Licensing Tools) and follow the steps there to install the license file. Once you are done with the license installation, you should be able to run Sim4life. Please contact s4l-support@zmt.swiss if you experience any issues.
  • Invalid Host ID
    Hi, Please contact s4l-license@zmt.swiss and inform about the issue you have. It is possible to lock your license to another network adapter or DSN.
  • How to set the windows as default?
    Moved
    T
    I can't find the explorer window anywhere. Any hints on finding it? I'm using version 6.2
