Anatomical Models
63 Topics 289 Posts
Working with models from the Virtual Population
  • phantom (ankle or lower leg) for tibial nerve stimulation
    Dear Jihan, You can use one of our available ViP models and crop it to include only the leg, or define a simulation grid that covers only the leg region. For the electrode array, our template models include a customizable Paddle Electrode, which you can adapt to your requirements. I hope this helps.
  • Lower limb-tibial nerve
  • Regional Models - Lower Limb
    Hello Silvia, Thank you for your reply and for clarifying this. Noted with thanks. Robert
  • anisotropy of electrical conductivity of muscle tissue
    AntoninoMCA
    Hi @fangohr, this is a very important question, especially considering the strong electrical anisotropy of muscle tissue. Unfortunately, the whole-body anatomical models provided with Sim4Life do not include DTI information that could be used to assign anisotropic properties. Therefore, if you want to model tissue anisotropy, alternative approaches are required. Some of these may be reasonable when the stimulation is regional, i.e. limited to a small number of muscles. In principle, Sim4Life allows you to model heterogeneous tissue anisotropy in two main ways. 1) Using subject-specific DTI data If you are working with a personalized model (e.g. a head model) and have subject-specific DWI data, you can proceed as follows: a. Reconstruct the DTI data from the DWI, bvec, and bval files (all standard outputs of MRI DTI). b. Convert the DTI into a conductivity tensor field using the Tuch model [1] Both steps are fully implemented in Sim4Life. Step (1) is performed via the Python API (please refer to the “Anisotropic Conductivity Tutorial” in the Examples section), while step (2) can be executed either through the Python API or directly in the GUI. The attached animation shows how processed DTI data can be converted into tissue anisotropy data structure using the Tuch approach, and assigned to WM conductivity. 2) Without DTI data (assumption-based approach) - Using an E-field distribution & Cylindrical Tensor Model If DTI data are not available, an alternative approach is possible, but its validity is entirely your responsibility. Sim4Life allows you to create a conductivity tensor field from a 3D vector field by assuming cylindrical symmetry of the conductivity tensor. In this case, the principal tensor direction is assigned according to the local direction of the vector field, and only the longitudinal (parallel to the fibers) and radial (perpendicular to the fibers) conductivities need to be specified (you can find these values in the IT'IS LF Database (https://itis.swiss/virtual-population/tissue-properties/database/low-frequency-conductivity/) The input vector field can be, for example, an E-field computed with any EM solver in Sim4Life, or a vector field generated via the Python API. One possible strategy would be to create an E-field aligned with the muscle fibers. This requires assumptions about muscle fiber organization — for instance, that fibers follow a diffusion-like process and extend from tendon to tendon. Under such assumptions, fiber directions could be approximated using an E-field computed with the QS-Ohmic Current solver, where the muscle is modeled as a homogeneous tissue and the tendons at the extremities act as Dirichlet boundary conditions. Please note that this is not a ready-to-use recipe. This approach may be reasonable for certain muscles and unsuitable for others, and it represents a strong simplification of the underlying physiology. You will need to define a plausible fiber model and then use Sim4Life to test and validate your assumptions. I hope this helps. If you need further or more specific assistance, please feel free to write again or contact the Sim4Life support team directly. All the best, Antonino [1] Tuch, D. S., et al. Conductivity tensor mapping of the human brain using diffusion tensor MRI. Proceedings of the National Academy of Sciences, 98(20), 11697–11701 (2001). [image: 1769594990533-anisotropy_from_dti_4.gif]
    T
    hi,bryn. Upon discovering your post, I downloaded the latest software version—9.2.1.19976. However, I was unable to locate the H. Personalised Transcutaneous Spinal Cord Stimulator. Might you kindly advise where I might find this?@bryn
    T
    @halder I hope this message finds you well. I am currently conducting a temporal interference (TI) simulation using the LF Electro Ohmic Quasi-Static solver in Sim4Life, and I have encountered an issue regarding the electric field distribution at the electrode–skin interface. Here are the specific settings I used: There are four electrodes in total. For the first pair of stimulating electrodes, I assigned PEC material type to the other two electrodes (which are not used for stimulation). The stimulating electrodes were not assigned a material type; instead, I only applied Dirichlet boundary conditions to them. In the voxel settings, the four electrodes were set with priority = 1, and the Duke model with priority = 0. For the second pair of electrodes, I applied the same procedure accordingly. However, during post-processing, I noticed that the region where the electrodes overlap with the skin shows no electric field distribution, which seems physically unreasonable. Could you please advise if there might be an issue with my setup or if there are additional steps required to properly model the electrode–skin contact in TI simulations? Thank you very much for your time and support. I truly appreciate your help.
  • How to get spatial coordinate information of an anatomical structure?
  • Drawing Toe Nails or other Details in Anatomical Model
    2 Votes
    @bryn ahh, I see. Thank you so much!
  • Importing anatomical models in the python script
    I ended up creating my Duke model in a separate script, where I first cloned him as static. Then I removed part of the body not relevant to me by boolean subtraction (entity by entity) and finally export the remain static model to a sab file, which I load in my main script instead of the entire Duke. It has been this confusion about entities and groups and what not disturbing the flow. Thanks for your suggestions bryn
  • ViP Shells for Sim4Life Users
    That's helpful. Thank you for the detailed steps @bryn.
  • Determine distance between bones and Antenna
    To measure the shortest distance between two entities, you can use the Python API: import XCoreModeling as xcm shell = xcm.GetActiveModel().SelectedEntities[0] coil = xcm.GetActiveModel().SelectedEntities[1] res = xcm.GetEntityEntityDistance(shell, coil) print(f"Shortest distance shell-coil: {res[0].Distance}") p1 = xcm.CreatePoint(res[0].ClosestPosition) p1.Name = "Point on Shell" p2 = xcm.CreatePoint(res[1].ClosestPosition) p2.Name = "Point on Coil" # This line is just to visualize where the measured distance was taken line = xcm.CreatePolyLine([res[0].ClosestPosition, res[1].ClosestPosition]) This would create something like this: [image: 1747752108672-c17b7bff-2d64-408c-88a7-fd83a4dadfdb-image.png] Some other snippets are shared here: https://forum.zmt.swiss/topic/565/geometry-modeling-snapping-to-endpoints-in-python-api/3?_=1747746585465
  • Modification of Tissue Volumes in the Anatomical Model
    I would add that in the first approach you might change the tissue property of the original bladder to something else, e.g. fat, to get the desired effect of shrinking or stretching the bladder without creating air holes. Btw, you can measure the volume of a tissue surface in the modeler using the measure tool.
  • Evaluation of head segmentation quality
    Okay, I will take those considerations into account. Thanks for the fast reply!
  • Automatic Head Model including 1010-System / Electrode Placement
    30
    51k Views
    @bryn Is the 6.8 displayed on the color bar the actual maximum field strength value? I exported the values and found that the maximum is around 5.9 instead. [image: 1735124755536-42fb974e-d830-42c2-8373-84c85ee63339-image.png]
  • Morphing Tool: How it can be used to modify the shape of the heart
  • Head tissue segmentation
  • Brain atlas
  • Neck flexion with Jeduk V4
    N
    @bryn Thank you again for your reply and the posture file!
  • Can I scale a ViP model? Why is the model "locked"?
  • Poser API documentation?
    Thank you for the detailed answer!
