Anatomical Models
63 Topics 289 Posts
Working with models from the Virtual Population
  • Pose User-Defined Surfaces/Entities
    39
    2 Votes
    70k Views
    Hi Bryn, I would like to ask a question regarding posing. My aim is to detect the variation in bone position from the skin in different poses (hypothesis being: as the soft tissues deform, the bone wont always be at the same position wrt the skin). I currently have 8 antennas placed around the skin which are supposed to mimic wearable antennas and I would like to move these antennas along with the pose. But if I link these antennas to the bone using "link-parent tool", the bone is always at the same location wrt to the bone irrespective of the pose. But I cannot link the antennas wrt to the skin as the antennas dont move with the pose. How can I do this? I would like the antennas which are placed around the skin to similar to the skin rather than the bone? Based on the first video in this chain, triangular meshes can be posed similar to the body. If I convert the antennas to meshes and then pose it, will I be getting the same issue i.e the bone is always at the same location wrt to the antennas? Thanks
  • Anatomical model extraction and dimension
    Thank You, It really works.
  • Subdivide the structure of SKIN into stratum corneum, epidermis
    Thank you! That helps a lot.
  • Locked items inside Virtual Population
    You can drag the entire group onto the simulation. The surfaces are tagged, and will be assigned to the correct material properties automatically. The reason for the locks is to prevent users from deleting individual surfaces, or editing them in some way. This would break the poser functionality. If you are bothered by this, or don't need to change the posture of the model, you can always select the bone mesh system and run "Clone As Static" in the context menu. https://youtu.be/CYI6rBPZw7E
  • Multiple simulations
    Hi Michael, I think you are talking about project files (.smash), and not about simulations. One project file can have multiple simulations in it. Your solution can be to use s4l_v1.document.SaveAs( "FileName" ). This will change the name of the current file from default to something you choose. Best, Habib
    You could use the IXI025 head: https://github.com/ITISFoundation/IXI025 Or any ViP model...
  • Wireless Power Transfer on Yoon-Sun
    License issue?
  • Taking geometrical measurements
    8
    Thanks a lot. I shall try that now. Regards, Vignesh
  • Surface projection tool
    8
    Hi, sorry. I still am facing issues. Since the antenna was too big for the thigh surface, I used a cuboid around the thigh to project the antenna. But, the projection is stil being deformed on the front and back. I have attached images of the process. I am not sure what is happening? b) Also, since the source (edge source for example) cannot be converted to mesh, do the snapping options (like snap to edge midpoint etc) work for meshes or how do we go about it? https://www.dropbox.com/s/vcbr606fiqxh4sl/ezgif.com-gif-maker.gif?dl=0
  • Poser Tool Apply button missing in version 7?
    Solved poser vip body model
    Hi, Can you please try to update your OpenGL to a version at least >3.2?
  • Linear Dispersion - DISPFIT assigning properties to ViP
  • Error : Can't create attribute 'material_version'.
  • Change the dimensions of the lung
    yes, background is treated as "Air".
  • What does the padding do?
    @farhana Hi Farhana, It is safe to put extra padding to avoid errors due to boundary conditions. Especially for antenna simulations, you should avoid fictitious reflections from the open boundary conditions (absorbing boundary conditions, ABC, or perfectly matched layer, PML). However, if you have a directive antenna, you can decrease the extra padding layers in the directions with lower radiation, and also you may use less PML layers in these directions as well. For the main beam direction, you should definitely use extra padding and high number of PMLs. These are my two cents for you. I hope these may help. Best, Sayim
    @farhana Hi, Good to hear this. I am using the following line of code to rotate an object around an arbitrary point (Xcenter, Ycenter, Zcenter) with rotation angles (Xtheta, Ytheta, Ztheta). This is more like a "Rotate" operation followed by a "Translate". Solid1.Transform = Transform( Vec3(1.0, 1.0, 1.0), Vec3(Xtheta, Ytheta, Ztheta), Vec3(Xcenter, Ycenter, Zcenter) )
  • How to import voxels from Matlab?
    @dbsim4 first to the second question: If you manage to import the voxels in Sim4Life, you can selected the LabelField entity and run the Image Tools / Generate Surfaces tool. I would recommend to turn on smoothing and simplification (edge length typically >= voxel size, depending on the feature size you want to preserve). To import the voxels in Sim4Life, you should write the voxels as a binary file (8-bit, 16-bit or 32-bit unsigned integer). A quick google search resulted in this MATLAB documentation page on writing binary data: https://ch.mathworks.com/help/matlab/ref/fwrite.html Alternatively, you could find a package to export the voxels as nifti file, and import the nifti file As LabelField (option in import dialog). The importer can also load an iseg tissue list, which assigns colors and names to the tissue labels. An iseg tissue list contains following information. First line is version, second line contains number of tissues not including background with label=0. The subsequent lines start with C and list the color (RGB-Alpha) and name. Example: V7 N3 C0.00 0.00 1.00 0.50 Bone C0.00 1.00 0.00 0.50 Fat C1.00 0.00 0.00 0.50 Skin
  • Bone identification using RF signals
  • Video of my model
    14
    8k Views
    Thanks @Bryn!
  • How Do I Precisely Align Sim4Life Models to each other
    Note for MRIxViP we align the models by moving them such that the origin is the projection (closest point) of the saddle point between nose and frontal sinus, to the plane through the ear canal (perpendicular to view direction) [image: 1641456564489-e42eb832-2116-4b1b-abcc-3a2075799c6d-image.png]
  • voxel of individual anatomic model creates holes
    The issue was solved and was due to a broken descriptor file. The upcoming release will provide more feedback /warnings if the descriptor cannot be parsed
