Installation & Licensing
37 Topics 128 Posts
Installing Sim4Life and configuring licenses
  • Ares Tools
    Hi Javier, When you start Sim4Life, Ares runs in the background and can be identified by the icon [image: 1625825900590-icon_arestray.jpg] in the system tray. Right-clicking this icon will give access to the Ares window. Please refer to the section "2.14.2 Ares - Asynchronous Remote Service" in the Sim4Life manual.
  • Problems after install SIM4LIFE 5.2 for SCIENCE
    Hi Andrei, could you please try with the latest release (V6.2) to see if you still have the same issue?
  • Simulation solver not progressing on GPU
    Great to hear! Keep in min that you can use the same Ares and allow it to use multiple versions of the solvers. It will then automatically select the correct one depending on the version of the GUI you are submitting the simulation from. It is always recommended to use the latest version of Ares, but there are no restrictions on the versions and the number of solvers it can use.
  • Open access
    It might be better to send your request to ZMT via email. Could you please send an email to "s4l-support@zmt.swiss" address? Thanks
  • Problem with Sim4Life Light activation
    Dear all, Thank you for your responses. The trick was in not "just" to disable the antivirus, but to completely uninstall it. Then the activation worked. Regards, Spuky
  • Sim4Life Light
    PeterStijnmanP
    as far as I know you can download it the software itself on all your machines, only when using it does it occupy your license, so you can only run one instance on one machine.
  • Troubles setting up new installation of Sim4Life
    8
    PeterStijnmanP
    Okay, a short update on this issue: I did absolutely nothing and it is fixed for me some how... There might have been a windows update that fixed the problem, not sure about that though. Curious if others have seen similar result.
  • Installation problem Windows 10
  • Problem with the tutorial of Sim4Life light
    F
    Downloaded V5.0 Lighty and the tutorials work - thank you!
  • Unable to connect ARES
    8k Views
    F
    Problem solved, my Antivirus was not letting Ares through.
  • Can't run T-NEURO simulation, fail to load mode or place sensors
    F
    my problem was solved. Thank you.
  • Sim4Life Light Activation Error
    Were you connected to the internet during the activation process? Could you please specify what windows version you are using?
    Yes, that is correct.
  • Sim4Life Lite acoustic simulation
    @habib Thanks a lot...I solved the problem already !
  • Missing MSVCR100.dll - Sim4Life fails to start
    Sim4Life's installer automatically copies required dll files. The files are official Microsoft libraries that Sim4Life redistributes. On some platforms, the files fail to copy and this causes the error message to appear. The solution is to use the official installer for Microsoft Visual C++ 2010 Service Pack 1 . https://www.microsoft.com/en-us/download/details.aspx?id=26999
