CAD Modeling
64 Topics 226 Posts
Working with CAD models
  • Holes in model produce voxels with 0V in EMLF simulations
    preview (still working on the distance from e.g. F7 to F9) [image: 1757340222351-c2ee64b1-55df-41d6-9583-bd5832ceb962-image.png]
  • How to get spatial coordinate information of an anatomical structure?
    To get the bounding box of some tissues, say Large_intestine_lumen Large_intestine_wall and test if some points are inside these tissues you can use the GetEntityPointDistance API, e.g., something like this: import numpy as np import s4l_v1.model as s4l_model Vec3 = s4l_model.Vec3 def sample_box(p1: Vec3, p2: Vec3) -> list[Vec3]: xs = np.linspace(p1[0], p2[0], 10) ys = np.linspace(p1[1], p2[1], 10) zs = np.linspace(p1[2], p2[2], 10) X, Y, Z = np.meshgrid(xs, ys, zs, indexing="ij") points = np.vstack([X.ravel(), Y.ravel(), Z.ravel()]).T return [Vec3(p) for p in points] def find_entities(root_group: s4l_model.EntityGroup, names: list[str]): entities = s4l_model.CollectEntities([root_group]) entities = [e for e in entities if e.Name in names] return entities if __name__ == "__main__": model_group = s4l_model.AllEntities()["Thelonious_6y_m_v3.1b02_posable"] entities = find_entities(model_group, ["Large_intestine_lumen", "Large_intestine_wall"]) p1, p2 = s4l_model.GetBoundingBox(entities) points = sample_box(p1, p2) inside_gi_tract = np.zeros(len(points), dtype=np.uint8) for entity in entities: distance = s4l_model.GetEntityPointDistance(entity, points) for idx, dist in enumerate(distance): # note: negative distance means inside the closed surface if dist.Distance <= 0.0: inside_gi_tract[idx] = True
    7k Views
    your code is still not using the FieldInterpolationFilter to interpolate the T1w image onto the same grid as the E-field. Note, the FieldDataTextExporter takes the output of the interpolator as input
  • Help with Petri Dish Geometry & Boolean Subtract Issue
    I recommend checking out the “Multiple Electrode in Homogeneous Medium” tutorial in the LF section. It includes a Petri dish with solution in the modeling part, which is directly relevant. You're absolutely right about the importance of the Boolean Subtract order. To ensure it works correctly, try the following setup: (1) Outer Cylinder: Radius = 18 mm, Height = 11 mm, Base at Z = 0 mm (2) Inner Cylinder: Radius = 17 mm, Height = 10.7 mm, Base at Z = 1 mm (i.e., shifted +1 mm in Z) (3) Perform Boolean Subtract: Outer minus Inner This setup should produce the correct bowl shape.
  • Discretized axons locked - how do I delete/unlock Neuron model objects?
    I would suggest first cloning the nerve trajectory, and then discretizing it. The result is an unlocked axon model. You can then delete the nerve trajectory clone if needed.
  • Surface projection tool
    @brown Thank you for the suggestion. I can surface project object now.
  • impossible drag and drop from non-CAD models
    For the unstructured version of the EM LF Electro you would first need to generate a tetrahedral mesh. The mesh can be dragged onto such a simulation.
  • Randomness in unstructured mesh generation
    N
    Hi @bryn, I'm meshing an implanted device as a faceted mesh which is then embedded in an octree mesh. This is all through the Python API.
  • Project line on to a layer
    This screen capture shows how you can then move/snap the "Spline Control Points" (the little white dots) to the offset surface: https://youtu.be/kveLjnKpWzU
  • Extrude 2D image as mesh or solid
  • Extract Points outputs only one vertex. Possible bug?
    The first method might not be working if your spline doesn't have a parametrization. If you click on the spline in the Model tree and don't see a list of points in the Controller window, then the information is no longer available and you'll have to stick to the second method.
  • How to add a layer with a thickness over a ViP model, e.g., clothing?
    15
    3 Votes
    11k Views
    Hello, Sorry I am facing an issue with moving antennas to different locations based on the steps above. I used three points on the skin and calculated the transformation between static and posed states. I used this transformation to transform the antenna position to the new position (using RigidTransform and ApplyTransform functions). However I get errors that the antenna source edge is within a solid. I have changed priorities during voxelling providing antennas higher priority but the errors still exist. What can I do? I would like to move antennas in a similar fashion to how soft tissues deform. Thanks Vignesh
  • How to export E-field to a custom grid?
    Hi, Thank you. I tried it but would like to plot the fields on a grid between antennas (as shown in red in the image). It is easy when the model is static but when posed, I am not able to get a grid at an angle. Thanks [image: 1710200782830-dd141418-49f3-4854-a083-853ccfa690dd-image.png]
  • 2 Votes
  • How to extrude along a line with a triangle cross-section
  • Line fed slot antenna
    Then you can keep the substrate as it is and translate the edge source (polyline) along the microstrip line until it also touches the ground plane (keeping it always axis-aligned).
    @MSJ the modify button is probably hidden on the top right, if you click the triangle where you see the three dots (...).
  • Using lumped elements (RLC) in the model
    lumped elements rlc elements
  • Export surface from Iso-Surface Viewer to Model
