CAD Modeling
65 Topics 227 Posts
Working with CAD models
  • Export surface from Iso-Surface Viewer to Model
  • How to scale imported CAD model in 7.2?
    Solved
    Yes, you cannot directly stretch a group. However, you can select multiple (non-group) entities and stretch them. The easiest is to press "Ctrl+A" (Select All), which will select all visible entities (excluding the groups), and then stretch those. You can also use the Python API. import XCoreMath import XCoreModeling Vec3 = XCoreModeling.Vec3 scaling0 = XCoreMath.Scaling(Vec3(2.0)) scaling1 = XCoreMath.Scaling(Vec3(1.2, 0.9, 2.0)) scaling2 = XCoreMath.Scaling(Vec3(1.2, 0.9, 2.0), origin=Vec3(120, 10, 34)) entities = XCoreModeling.GetActiveModel().SelectedEntities for e in entities: e.ApplyTransform(scaling0) the different scalings are uniform scaling non-uniform scaling non-uniform scaling wrt to the (non-zero) origin=(120, 10, 34) https://youtu.be/XCOM6uBFBRM
  • Waveport error
    Hi, How do you ensure they are in xy,yz or xz plane. Visually they are but I still face the error?
  • How to draw a capsule in Sim4Life?
  • Export spline points
    python
    That worked- thanks a lot!
  • Waveport - TEM mode
    Hi, I decreased the max step of the dielectric material in the coaxial cable, but still got the same warning. I have two questions: Is there are formula which can be used to determine the cross-section? How does the warning affect the result? Thanks
  • Waveport guide error
    8
    Hi, I would like to power the two waveports with an input which is 180 degree phase apart between each other. The antennas are constructed in a differential manner to increase penetration. I am not sure how to provide the power input to the waveport guide Thanks
  • Model not updated when entering dimension manually
    Hi @bryn , thanks for looking into this. I can reproduce what you write. However, in my case it is a little different because I do press Enter and still it would not update. Unfortunately, I do not know how to reproduce this behaviour in a fresh project. I will hope that the solution to your bug will also fix the bug that I encounter, though. Thanks!
  • Evaluate distance along a (curved) line
    python
  • I need to draw an ellipsoid
    Hi, please check the forum entry below: https://forum.zmt.swiss/topic/476/move-pallet-missing-in-7-0?_=1669743433381
  • Add antenna to body part
    Hi Vignesh, Yes, "Surface Projection" tool should help you to place the antenna on a surface of a human body model.
  • move pallet missing in 7.0
    11
    7k Views
    Thanks a lot
  • Saving cut model
    Hi Tomasz, I don't think the access violation error has anything to do with "protected models". I think this is a bug that should be reported to the support. What version of Sim4Life are you using? did you cut the "posable" Jeduk, or did you first "Clone As Static" did you cut using the Python API, or in the GUI? if you save the model as .smash or export as .sab/.sat file, is a file written? Can you load it? what other types of entities are in the model? what happens if you copy the model entities and paste them in a different instance of Sim4Life?
  • Problem with surface projection tool
    Thanks for your useful suggestion! The problem I met was that the patch partically inserted into the human head, not on the surface, shown as a more clear figure below.Both gaps and overlaps exist between the projected cylinder and the skin. [image: 1652666210989-2e90feb6-bff3-43c1-99e9-4f56d3b70d96-image.png] I have remeshed the human skin and the patch, to make the voxel sizes approximated match, and it worked out! Hope this will be helpful to others with similar problem, the mesh is the crucial role.
  • How to create the model by 2D picture
    @bryn Thank you very much.I had succeeded.
  • Avoid solid
    Only by snapping to objects. One strategy can be to use planar cuts to snap inside solids/surfaces
  • Create a loop using wire toolbox
    Thanks @ofli and @bryn! Yes, that's what I'm doing now, I just create them in multiple segments.
  • Problems with AC
    Dear Andrei, Could you please check that you have enough disk space? the error message specifies: "No space left on device". Best, Melina
  • wrapping tool
    @mkn the feature is available in v6.2 (or even v6.0). You select the (triangle mesh) entities to project and then the target entity (last), and start the Project / Surface Projection tool. While the tool is often useful, it can fail when the entities to be projected are nearly as large as the target surface. It usually also helps to ensure the target surface is non-manifold (Mesh Doctor -> Make Manifold) and has no degenerate triangles (Mesh Doctor -> Create Degenerate Patch -> Local remeshing of patch(es)).
  • Problem with Boolean operation
    I think the error "didn't manage to link up hole" usually occurs when the two objects (involved in the boolean operation) have nearly parallel touching surfaces. You could try: (always first make sure surfaces are manifold) make the cylinder overlap more with (deeper in to) the skin
