CAD Modeling
65 Topics 227 Posts
Working with CAD models
  • iSeg Focused Ultrasound Acoustic Tutorial problem
  • [SOLVED] How to route a pacemaker lead?
    Thank you @bryn! I will adapt this to my needs.
  • Sketch spline fails systematically
    I agree that it is unintuitive that the Spline tool stops when it snaps to a vertex. I will create a bug report. There are tools that may help you: Wire Tools / Routings Tool Box / Approximate Wire Wire Tools / Fit Spline The Approximate Wire tool allows you to specify the number of handles you want. It creates a parametric spline with handles (if Parametrize=True), so you can also edit it interactively by moving the handles. I guess you can also create a spline using a list of points using the Python API.
  • Extrude whole model, not just individual volumes/lines
    I guess you have different options, in order of complexity stretch the whole model (it is 2.5D I think?) if there is something in the center that should not be stretched (electrodes?), you could cut the model (all entities) in three parts: bottom, center and top. you could stretch the top/bottom and then boolean unite them with the center. you could select the faces e.g. at the top (sub-picker) and offset them. you have to do this separately for each region. to specify the exact extrusion length, you can start pulling the arrow and then press the space key to type the offset/extrusion length (see attached gif)[image: 1633937557311-extrude.gif]
  • How to scale a Model to a different size?
  • How to rotate around camera instead of around grid?
    camera rotation
    @montanaro Works like a charm, thank you!!
  • How do I clone an object and preserve the parameterization/expressions?
  • Setting up voxel priorities in model
    Thanks for the answer. I thought there was a way since the VIP models handle this so well, but Python should work as well. Or is there a way to to sort the priorities by entitiy name?
  • CAD Projection tool
    I see- thank you!
  • how to draw exponential line
    Here is a piece of code that creates a coil wrapped onto a torus, using lines defined from 3D parametric equations. It makes use of Law(), Curve(), CreateWireBody() and SweepAlongPath() from the XCoreModeling package. import numpy as np import s4l_v1.document as document import s4l_v1.model as model import XCoreModeling def create_toroidal_coil(R, r, m, n=1, i=1, name="Toroid"): """ Create a spline model object with a spiral shape. The shape is defined from a 3D parametric equation. """ # equation b = 2. * np.pi * float(i) / float(m) x_component = "({R}-{r}*cos({b} + {n}*t)) * cos(t)".format(R=str(R), r=str(r), b=str(b), n=str(n)) y_component = "({R}-{r}*cos({b} + {n}*t)) * sin(t)".format(R=str(R), r=str(r), b=str(b), n=str(n)) z_component = "{r}*sin({b}+{n}*t)".format(r=str(r), b=str(b), n=str(n)) path = XCoreModeling.Law("vec({}, {}, {})".format(x_component, y_component, z_component)) curve = XCoreModeling.Curve(path, 0.0, 2.*np.pi) # Create a spline wire body to visualize wire = XCoreModeling.CreateWireBody( curve ) wire.Name = name torus_centerline = model.CreateCircle(model.Vec3(0,0,0), model.Vec3(0,0,1), 10) torus_centerline.Name = 'Centerline' torus = model.CreateSolidCylinder(model.Vec3(10,0,0),model.Vec3(10,0,0), 3) torus.ApplyTransform(model.Rotation(model.Vec3(1,0,0), np.pi/2)) XCoreModeling.SweepAlongPath(torus, torus_centerline, make_solid=True, cut_off_end=True) # Theoretical self-inductance: area = np.pi * (r*1e-3)**2 L_theoretical = 4.0e-7 * np.pi * n * n * area/ (2.0* np.pi *R * 1e-3) print(L_theoretical * 40) return wire, torus if __name__=="__main__": wire, torus = create_toroidal_coil(10,3,1, n=100)
  • Import a 3D geometry to sim4life
    when you write inventor, do you mean "Autodesk Inventor" or "Open Inventor"? I guess the file is some kind of assembly, which is exported as a single STL file. STL does not support multi-part models, so you would need to export each part a separate STL file (or other format supported by Sim4Life), or you export it to a file format that supports multiple parts (ACIS .sab/.sat, STEP .step, ... VTK .vtm (multiblock)). STL also only supports triangle surface representations, so if you had a NURBS CAD file, you loose the that by exporting to STL. Searching for the topic I found this information for Autodesk Inventor to export as a multibody sab file: https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-convert-Inventor-Assembly-file-to-a-multi-body-part-file.html btw. if the points in different parts aren't coincident, you may be lucky with your single STL file: try Modeling -> Mesh Tools -> Separate Meshes. This could separate disconnected parts.
  • Ellipsoid
    Yes, there is. Create a sphere, then use the "Move" tool and look for the "Stretch" button on the right side of the 3D window. You can then stretch any of the 3 principal axis of the sphere.
  • Medical Image Segmentation
    To comment on this case. The surface extraction in iSEG is inferior to the surface extraction in Sim4Life. So you probably want to export the labelfield as voxels (e.g. in Nifty, Nrrd or Metaheader format - the VTK format does not preserve the transformations correctly). You can also extract the tissue list as txt file in iSEG in order to set the tissue names e.g. via a python script in Sim4Life.
  • 'Electroceuticals - Implantable Stimulator' CAD missing (S4L Light)
    @Jexyll_S Oh perhaps, thanks!
  • Export parts of ViP models as IGES
    Hi Micol and Frodi, One free alternative is to use the shell provided with the Fitness Tracker tutorial. This is the skin shell of the model Billie. It is not license protected and can be exported to any one of the available export formats. Best, Habib
  • Sweep a cross-section geometry along a spline
    Hi, when sweeping an object along a path, the normal of the cross-section should in principle follow the path. This, however, does not prevent having self-intersections in locations where the curvature of the path is too large compared to the size of the cross-section. The best way to experiment (different geometries, different paths, etc...) is to use the Python API: import s4l_v1.model as model from s4l_v1.model import Vec3 import XCoreModeling spline1 = model.CreateSpline([Vec3(0,0,0), Vec3(50,0,0), Vec3(50,50,50)]) section = model.CreateCircle(Vec3(0,0,0), Vec3(1,0,0), 10) region1 = XCoreModeling.SweepAlongPath(section, spline1, make_solid=True)
  • Thicken the helix wire
    @PeterStijnman Thank you so much for your solution,I will try it.
  • Helix problem
    @LCL You are welcome! Enjoy the Helix tool and do not hesitate to post some screenshots on this forum if you create some nice looking helixes
  • Voxelling problem -posable model
    2 Votes
    Those look llike ghost voxels (i.e. voxels produced by a bug in the voxeler). Look at the regularity of those voxels. If this is reproducible, can you please provide a project file with that model in it and report a bug case?
  • Boolean operation with Anatomical models
    just to comment on doing booleans with licensed models. this is completely possible, as Suchit says. Sometimes I think users get confused by the lock symbols shown in the model. These locks are not related to the license protection at all, they are there because the model is posable and modifying individual parts would break the posability. For you I would suggest to download the shell (surface enclosing the complete model) of DUKE and do the boolean operation with the shell only. For Duke you could use: https://itis.swiss/virtual-population/virtual-population/vip2/duke/duke-whole-body-shell-v2-0/ Since the shell is not license protected you can modify it, save it as STL or whatever format and load it other software tools if needed (e.g. MATLAB). To make it a solid the easiest method is to import the STL file and check the box "Import as Solid". We are planning to restructure the downloads soon, and I want to add the shell surface by default to the zip file containing the full V3.x model, since it is often useful, e.g. to create uniform thickness offset surfaces (skin layers), and other operations.
