270 Topics 804 Posts
    16 40
    Hello, To use multiple instances of the same HOC file in a single simulation, the neuron model must be defined as a HOC template (see Manual section 2.13.4.7.2, “HOC Templates”). In a non-templated HOC file, section names are defined globally. Loading the file more than once therefore creates duplicate section names, which NEURON does not permit. A template gives each neuron instance its own namespace, allowing multiple instances to be created and connected without naming conflicts. Please also ensure that the HOC template meets Sim4Life’s compatibility requirements, including matching the file and template names and placing the compiled mechanisms in the same folder as the HOC file.
    After creating the voxels for a simulation, the input file can be created without submitting the simulation by right-clicking on 'Solver' in the simulation configuration and selecting 'Write Input File'.
    The Thickness Factor defines the thickness of the Piezo element and the Reflector as a fraction of the acoustic wavelength (determined from frequency and Speed of Sound). By default, n=10, so the fraction is 1/10. This is a parameter which should help to nicely design the SEFT such that it gets correctly voxeled later on (so not too thin) but also doesn't cover too much space (not too thick). Theoretically, the reflector and the active element can be as thin as a single cell layer, but you don't know the computational cell size when drawing the model. Since the voxeler is set to have a max step size of lambda/10, due to stability considerations, the Piezo and reflector will always be nicely and continuously voxeled when using the default Thickness Factor of 1/10. You can find more information about the Acoustic Solver, including relevant equations, in a thesis titled "Multi-Physics Computational Modeling of Focused Ultrasound Therapies", upon which the Acoustic Solver in Sim4Life is based.
  • Question Regarding Temporal Interference Tutorial in Sim4Life
    I
    Hello, I have the same issue. Currently using Sim4Life 8.2.0.16876. I wonder if there is any new update on this. Many thanks, Ines
  • EM-LF Solver- Tutorials Not Running
    OK, I will share it. Thanks
  • XCore.CLog error
    it seems to happen (in Sim4Life 9.0.0) when you switch to the analysis tag after sending a solver job on the cloud. I guess it can be ignored and will be fixed in an upcoming update-fix release
  • Solver Error in EM-LF Simulation on Yoon-son Model
    em-lf
    Hi, Did you run your simulation using our SMALL server (16 CPU cores, 32 GB RAM) or the LARGE server (48 CPU cores, 96 GB RAM)? Also, could you let us know the total number of cells in your simulation? As a general suggestion for optimizing memory usage, you can start by running a simulation with a coarse grid to identify regions where the fields are negligible. Based on this, you can adjust the grid padding settings to exclude those body regions from the simulation domain, effectively "cropping" unnecessary areas and reducing the computational load.
    I used it to get information for high level workflows. It can also come with suggestions for code, obviously, but it often invents functions that don't exist and implementations for me has not been very AI-powered. But the theoretical discussions are quite good.
    Here is the Web Manual section containing this information: 2.11.3.9 Neuro-stimulation with Imperfect Electrode-Skin Contact. Additionally, Yoon-Sun Arm Stimulation tutorial also includes this new feature. For more information or examples you can contact us at s4l-support@zmt.swiss. Thanks!
    Hi In Sim4Life the tissue properties are provided as a single values. However, the IT’IS website provides supplemental information on the tissue properties. In addition to the average value, you can find the standard deviation, minima and maxima. Low Frequency (Conductivity) » IT'IS Foundation](https://itis.swiss/virtual-population/tissue-properties/database/low-frequency-conductivity/)
  • Jobs suddenly remain queued indefinitely
    13
    9k Views
    P
    After a call with S4L support, here is the solution for future reference: My machine had two GPUs connected, one of them old and deactivated. However, the script ExtractCudaInfo.py detected both of these in the line 'num_gpus = int(xml_root.find("attached_gpus").text)' and then got stuck trying to find information on the deactivated GPU. A quick fix for the issue is therefore to manually set the correct number, in my case 'num_gpus=1', in the script.
  • High Field Values at Extremities
    Hi @bryn, I think you’re right. The issue appears to be related to the boundary conditions on the outer bounding box. I changed the boundary to a flux(0) condition, and that resolved the problem with the localized high field values at the extremities. Thank you!
  • "wire radius"
    Please give more context. E.g., "in the modeler when I use tool X", or in a "Y simulation" there is an option. or in this other thread (link) I asked about Z Then it will be easier to answer your question.
  • Modulated source in thermal simulation
    P
    @Sylvain Hi, thank you for your reply. I changed modulated field to El. Loss Density and everything works.
  • Thermal, unable to write input files.
    Thank you. Uploaded.
  • MQS solver errors
    sending you an email via support
  • How to get inhomogeneous B0 maps
  • Simulation outputs
    Great! Goit it, thank you so much. One last question regarding where the simulation outputs are located and saved. The coordinates of the voxelized entities where can be found? Thank you so much for your time
  • White matter anisotropy
    8
    @bryn Thanks, I found it!
