270 Topics 804 Posts
    16 40
    Hello, To use multiple instances of the same HOC file in a single simulation, the neuron model must be defined as a HOC template (see Manual section 2.13.4.7.2, “HOC Templates”). In a non-templated HOC file, section names are defined globally. Loading the file more than once therefore creates duplicate section names, which NEURON does not permit. A template gives each neuron instance its own namespace, allowing multiple instances to be created and connected without naming conflicts. Please also ensure that the HOC template meets Sim4Life’s compatibility requirements, including matching the file and template names and placing the compiled mechanisms in the same folder as the HOC file.
  • stimulation
    @gbgbha you are right.thanks you very much.
  • How to use unstructured LF solvers with parameter sweeper?
  • Acoustic simulation with high frequency (ex. 1 MHz)
    19
    12k Views
    @montanaro Thanks for your clarification.
  • Solve ∇⋅σ∇ϕ=0 in a cylinder...
    @sylvain I learned your before reply.I want to know how to set the voltage of electrode to the desired value or frequency.how to set the expression(sin(2pi*2000t)) in siM4life? best wishes
  • Magneto-QuasiStatic: Interpolation error
    hi, regarding padding: as a general rule, if you are not sure whether a numerical parameter will affect your simulation results, the best course of action is to just "try and see". Change parameter -> see if it affects the results significantly. For the padding, you should try to increase it and check that your simulation results are not affected by spurious "boundary effects". as for tutorials: yes, in principle you should obtain the same results as shown in the manual. If you do not, please check carefully that you followed the steps faithfully (pay attention, for example, to the Normalization settings in the Analysis/postprocessing part, after extracting the field sensors - forgetting to tick this box would often lead to orders of magnitude difference in the results).
  • cannot find EM-FDTD solver in Simulation tab
    @Sylvain thanks for your reply! I did check with my supervisor and it is true that our license does not include that solver as our project does not need it.
  • Pig Simulation: Failed to create heat source field extractor
    28
    50k Views
    Yes I did mean wavelength, not period .. That's the drawback of running high frequency simulations in FDTD, they require a lot of voxels ... If appropriate, try running it at 500 kHz and then update the automatic grid settings ... The auto grid settings is based on the material in your domain that has the lowest speed of sound, please remove air from the simulation domain if appropriate ... One of my previous comments tells you how to calculate the wavelength, the units and magnitude seem wrong in yours, remember that you're not using the speed of light to calculate the wavelength, you use the speed of sound in the medium (around 1500m/s)
  • Flux A/m^2 Analysis not Working
    What is the error message indicated by the red triangle? Maybe the flux is negative. Did you try adjusting the limits on the colorbar?
  • iSolve failed in pig simulation.
    Hi, this typically happens if some material that is voxeled is not found. If I had to guess, I'd say that you have a source and no corresponding material (the source element should be in the Sources and Materials)
  • Some errors are reported about the Neuron module
    If I read the message correctly, it seems that another program is interfering. Have you tried to uninstall the Yale Neuron Solver?
  • I can't control the beam direction of circular array antenna
    @rose, you write "it was a bit different from the theoretical result", but unfortunately I don't fully understand what you did, what you are trying to do, and what you are comparing your results to. Perhaps if you describe (with e.g. screenshots and equations) both what you did and what the "theoretical results" I can try and find why they do not match.
  • Problems with my simulation
  • Help with my simulation
    Hi Javier, What error messages are you getting with Endring 1 simulation? I assume that you have already checked the tutorial "3.1.9 MRI Lowpass Volume Coil" which might help you to make sure that your setup is correct.
    @rose see my answer here
  • User defined waveform not importing correctly
  • What is considered "low frequency" for EM LF Simulations?
    See the Sim4Life Manual (2.6.1 EM LF - Simulation Theory) ωσμd2≪1^ The quasi-static conditions are sufficient conditions for the quasi-static approximation to hold. In practice, there are cases where the quasi-static approximation still yields accurate results even when the quasi-static conditions are not satisfied. The guideline for this type of cases is to compare to results from full-wave simulations. A table of the quasi-static approximation criteria for every simulation is written in the log file: Solid settings: frequency = x Hz, characteristic length (worst case domain diagonal) x Epsilon Mu SigmaE QS Approx. Quality Static Magn. Field SigmaE/wEpsilon Solid name The column QS Approx. Quality and Static Magn. Field refers to quasi-static conditions. The column SigmaE/wEpsilon indicates whether the displacement current ( ≪1 ) or the ohmic current dominates ( ≫1 ). 2.6.1.4 Choosing the Appropriate Low Frequency Solver has further details
  • Tutorial Grid Error "Yoon-sun Arm Stimulation"
    Thank you @LJ and @Habib!! Fantastic explanations, I understand
  • What is the mismatch efficiency?
    @rose your simulations are most likely done with a 1V voltage at the excitation source (that's the default setting). This is perfectly fine from a numerical point of view, but in practice (e.g., if you wanted to compare with measurements) you probably want to normalize your results. In the Far Field Sensor, for example, you can normalize to a Total Available power of 1W (say). This way, you will be comparing apples to apples. That will not change the value for the Gain, though (since it is a power ratio, independent of scaling). This must come from either a difference in some aspect ratio of your dipole, or simply that you did not change the dimensions in the same proportion (1/10th) as you changed the frequency.
